Mine work also. I wonder if the dash has a light indicator for this? Maybe the indicator is out.
Here is something that a friend of mine had me try to see if my clusters were working ok.. maybe you could see if there is a code that is returned and maybe a bulb out.
DO THIS:
Push in the reset spedometer button
Then turn on ignition
Continue pressing spedometer/trip button for 10 sec
then release and watch mileage readout.
It will test your clusters try the lights and test your guages.
It may return a code or two.. write these down and post them for what they might be.
Also pay close attention to the ABS light and make sure it works on the dash.
Just thought of this.. I think maybe when you turn on the key the ABS light illuminates for a second or two... not sure.
Damon
