1 - 11 of 11 Posts
where is the best spot to put the injection head? I dont have a diagram so i need to know where you introduce the water meth into the fuel or air system
Most folks drill and tap a port (or two) into the intake horn.
I drilled and tapped mine in three places, two for the nozzles and one for the pressure sensor.
thats what i did but i just tapped in to my boost line instead of drillen another hole
im thinkin of running water meth once i get my bigger injectors, i was wondering if maybe it would be a good idea to put a nozzle on each side of the intake horn to make a better spray pattern?
The velocity of the air passing though the air horn is so high I doubt it makes any difference on nozzle placement as long as it's close to the intake.
im looking to build my own setup and was wondering if i could put like 3 or 4 nozzles down the intake plate that runs down the head?? would this be a good idea?
put two in the intake manifold not the horn. you will inject more evenly.
also what do yall think about putting 1 nozzle before the intercooler?
Bad idea. You want the meth to be atomized (fine mist) after it goes though the cooler and all the tubing it would be a dribbling liquid.
1 - 11 of 11 Posts
