Hi ive searched for an answer and came close but i wasnt satisfied with the answers i got so Im starting a new thread.
Last week i was out gathering firewood in the forest, when i jumped in my truck to move to the next spot a few feet away, it cranked over but no start. So after a few trys i got to thinking what the problem may be, usually itll start in one crank rightaway. Initially i was thinking FSS, eventhough its only a couple years old, ive been experiencing problems with it shutting off and working intermittantly. With no tools I just tapped on it with the key on hopeing that if it where stuck shut, the blows would help it release...no go.
So Air leak and clogged fuel fiter crossed my mind. I replaced the fuel filter with a new spare i carry with me, and at the same time I inspected the fuel line routing and looked for abnormalities. I then proceeded to prime the pump (LP piston pump) to fill the new filter. When I crancked it over I got a few sputters but it then died and just cranks after that. So I primed more like 30-40 pumps each time trying to start it after a revolution of pumps, same results, sputtering...then finally after a few of those trys i got it going!!! but when I went to throtle it up it died. Frustrated, in the middle of nowhere, getting dark and cold, I crawled under my truck tracing down the fuel line (plastic to the tank) It had all the signs of an air leak so thats what I was thinking.
I found part of the fuel line was rubbing on the frame the area was already covered with brake fluid from a leaking master cylinder, and diesel form the filter swap, so I cleaned it off as best I could and primed and cranked then looked again to see if i saw fuel on the line. No fuel the rubbing area didnt seem to have a pinhole just a slight rubbing, so I tapped the line with electrical tape. and primed the pump again, then boom it fired right up and continued to run normally...So I thought I need to replace the fuel line
The next day was dedicated to fixing my truck, now to back up a few months, my fuel pin o-ring is leaking and has been, and i recently started seeing wet spots at the throttle lever shaft. I purchased the bosch gaskit kit and it has been wainting to be instaled.
Now, I have the proper fuel line (upgraded to 3/8) push lock fittings, and Draw straw.
I first started by taking the tape off the fuel line to get a better look at it in the light, and thereis definatly no hole or leaking in that area, or any area on the fuel line
And on a side note i heard a faint hissing as I was primimg the pump the day before on the trail, It sounded like it came from the fuel pump fuel filter area but was never able to confirm where.
I took apart the AFC housing and replaced both the fuel pin o-ring and the throttle shaft o-ring, necessary gaskits.
After I bolted it all together it was dark, and wasnt able to drop the tank to do the fuel lines.
So i just started it up and everything was fine
My truck is a daily driver and I just simply ran out of time to dive into replacing the fuel lines. So I just kept driving the truck.
Its been more than a week and Ive been on some trips down and back to town with no more air leak/starting issues. Im still gonna replace the fuel line and draw straw, but it seems that wasnt the problem.
(question)
Is it possible that the air leak was from the AFC leaks?? doesnt seem likely to me and I just hate not being sure if the issue is fixed or not by not knowing the exact cause...
Thanks for reading my long story....:thumbsup:
(question)
