1 - 4 of 4 Posts
Before I start, I know we don't buy trucks like these for fuel mileage or economical driving. My concern is with the dramatic change. I want to know if something is wrong, or if I caused the change.
I just leveled the truck and put an aggressive 35x12.50x20 on it, which I know didn't help. I went from averaging 16-17 on a 265/70/17 to only 11 or 12 mpg. If that normal?? How much will deletes help?
Yep, you went from a tire approximately 32 inches tall to one almost 35 inches tall so your speedometer/odometer is off. No doubt the small lift and taller tires had a negative impact on you MPG's but you will not know how much until you correct your speedometer/odometer.
Reactions: N of 60
Gotcha, makes total sense. I just didn't figure that it would amount to so much of a difference.
1 - 4 of 4 Posts
