I do. I owned a set of their 55lpm injectors in a VE and a set of their 90hp ones in my ppump motor before I popped a hg and found cracks between the valves (not injector related, PO stupidity related is my guess). To date, they are the best injectors I've owned.
In all I've ran stock injectors, a set of ddp 55lpm VE.
What kinda differences did the 55 lpm make over stock sticks
Sent from my SCH-I535 using AutoGuide.Com Free App
on a stock motor with only a cheap home made intake, stock dyno, dennyt dyno, then ddp4 55lpm injector dyno with no tuning:
Put 'er on the Dyno Sat. Baseline, DennyT then DDP4 - Dodge Diesel - Diesel Truck Resource Forums
^^ Keep in mind that I hadn't touched my fuel screw at that point, and had done virtually no tuning. I did however make sure I had full throttle travel and had switched my throttle arm to the inner hole and put spacer washers on the pedal cable so I had full throttle travel.
after all that I then added 4" exhaust and an he351 and went to 248hp uncorrected but lost a bunch of tq, but that, i am guessing, was because I was starting to wear out the converter and was starting to push past it's working power i think.
When I switched to the he351cw and 4" exhaust I could turn the wheel all the way to one side and step on the accelerator with no braking whatsoever, I would spin the truck 180* the other way and just completely roast the tires and not move forward. Again, with no braking at all. But then the transmission (or the converter, idk which) started to not grab as much. By the time I hit the dyno it was noticeable. my old dodge in that state was far more fun to drive than this ford with the new motor is. The ford is much heavier and the LS rear doesn't work at all, where as the LS in the dodge worked perfectly.
EDIT:
It would appear all those links are broken... lame. well this should be a link to the album on photobucket
http://s113.beta.photobucket.com/user/rlebar/library/dyno sheets
Stock (all numbers are uncorrected here)
hp:141
tq:379
DennyT pin
hp: 168
tq: 512
gains:
hp: 27
tq: 133
DennyT pin + ddp 55lpm injectors
hp: 231
tq: 675
gains:
hp: 63
tq: 163
