if you have a catastrophic engine failure, I can pretty much promise you that you also voided your engine warranty :S:It will not void the entire warranty. Talk to your dealer about it. They may be open to working with you. My dealer told me that getting rid of the emissions would be voiding the emissions warranty, which I'm ok with that :thumbsup:
Jason
They cant trace the programmer, they can trace resets on the ecm and codes that were set, even if you clear a CEL code it still leaves the history, unplugged sensors, ect ect. but they cant tell or prove you were running a programmersimple answer.......yes. everything is traceable nowdays.
Maybe. Maybe not. They've replaced engines under warranty before with aftermarket parts and programmers.if you have a catastrophic engine failure, I can pretty much promise you that you also voided your engine warranty :S:
just saying
