1 - 4 of 4 Posts
Sweatin to the oldies
Ingredients: 4" inlet aftermarket air filter, a piece of 4" exhaust pipe, some scrap metal, and ingenuity.
The ominous hole from where my former air box sat.
Pipe was a bit small for the tube...
Solution: Use the rubber grommets included for a 3 or 3.5 inch inlet to make a ring around the pipe and make up the difference.
Now we Roll!
Took the pipe loose and made a bracket for it to attach to the bolt the stock box was held in place by.
Some paint... and voila!
(If all the splattering in there confuses you, I replaced the thermostat while I was at it. :D )
And it sits far enough inside the fender to not worry about it getting wet.
I have the same filter.
Thanks, and yeah I made it. It's 18ga steel, the same stuff my mirror brackets are made out of. BTW yours looks good too. :thumbsup:
Reactions: thechoochlyman
1 - 4 of 4 Posts
