Thanks for being here. First post. I've done a lot of searching, but can't find this EXACT info. I have a cummins 5.9 in a '96 Bluebird bus. AT, about 160K. Runs well, etc. I have let it sit since spring, and it won't start. I have had it for about 2 years with very little use, but bought it just to have the engine. When I first bought it, when starting, it would ALWAYS do the turn over a bit, click repeatedly a bit, turn over a bit, and finally fire and run. I have let the batteries die a couple of times over the years, would remove and charge them, and it would do the same thing but always start. Well, now it will only click, and I've gotten VERY minimal and super slow turnover, but mostly just clicks. I've read about replacing the starter contacts, but just want to make sure that it is not my batteries just being old and weak before I do the starter contact surgery. I have hooked up my IH 7.3 F350, with the batteries in there and got very minimal help. I have cleaned off cables and terminals, etc. I cleaned off ground cable attachment point (on the frame) and even ran a single wire ground from the batteries to the alternator bracket to try to make sure I had good ground. I have the batteries out now, and have been charging them, but they are 2 of those behemoth, 1700 CA and 1400 CCA triple size batteries that, according to NAPA weight somewhere in the 132 lbs each range, so slogging them back and forth multiple times while experimenting with this issue is not an idea I relish. I do not have a shop, and am working in a parking lot about 100 yards from my place, which is a split level kind of set up, so I have to lug the batteries up and down stairs to take them inside to charge them. And, the kicker, of course, is that funds are very tight, so I can't afford to just go buy $450 worth of batteries if that ISN'T the problem.
These 2 batteries were cabled up in series, but, MAN, that's a LOT of CA's and CCA's. Is that REALLY needed? I was hoping to drop in a couple of my lesser batteries, attach them in series, and hook up jumper cables to the 7.3 and get enough juice to start her up. So far that has not happened!
So, the moral of the question (yes, I know that;s not a real saying), is, how many CCA's should I need in a battery to get this thing to turn over??? I could maybe even go buy 2 new REGULAR size batteries that I could put in there, but between expense and size/weight, I would MUCH prefer to do that over getting 2 more giant ones! I've seen people talking about having single 925CCA batteries in their gen 1 5.9's and that was enough. So, I know it is a generalization, but what is the smallest size/powered battery I should be able to effectively trouble shoot this with?
I'm not sure if you need more info than that, but was guessing that turning over a 5.9 is turning over a 5.9, and didn't think much more detail would be needed.
Not that its URGENT, but I'm also curious as to why they WOULD use these 2 huge batteries, if most 5.9's can get away with one or two "normal" sized car batteries. I would assume that the Alt is running most of the juice for the lights on the bus, and it is a straight school, bus, no extra options or luxury model that needs lots more elec power.
Thanks for any input, ideas, thoughts, or questions that will help me work through this. City code enforcement is on me to get it moving again so it is not classified as a non-runner or abandoned! Thanks!
