I cant get those bolts off for nothing, is there any tricks to get them loose?
Cummins Fanatic/INJECTION PUMP TECH ADVISOR
Are you referring to the 4 slot screws that hold the aneroid cover down? I generally use a large screw driver that I can attach a wrench to allowing me to get more torque when breaking them free.
Yep, i used large screwdrivers they just kept jumping up and im afraid of messing up the bolts.
I have to push down on mine real hard the first time while turning. VIce Grips on the heads of the bolts works, too.
Daniel
Thanks, im getting ready to give it a second attempt here in a few minutes.
An hour later and no luck. The heads are starting to get burred up.
Need a larger screwdriver. One that just barely fits the slot.
