1 - 17 of 17 Posts
Hello what have you guys had better luck with? The amsoil bypass filters or the lf9208 enclosed bypass Venturi filter?
Thanks
Without a doubt a real bypass system will out perform the filter, but the deciding factor to me was cost/payback. When I was driving 80 or 90k a year oil was less than $10 a gallon and a sample was in the $25 range. The benefit of a bypass system is extended drains, not much else. it would take a lot of extended drain oil changes to make up the money spent for a bypass system Now that oil is more expensive (and better quality) the cost/payback time is less but I no longer driver 80 or 90k a year. If I were to pull the trigger on a bypass system the last one I'd consider is Amsoil anyway. There are several better, less costly ones available.
I'm sure you can build your own system for next to nothing. There's a port on the oil filter housing for it.
Okay, are you using a regular filter now
No, I'm using the Fleetguard LF9028 venturi filter. Filter changes at 12,500 and oil changes and oil sample at 25,000.
I used the amsoil a home made, and now use the lf 9028 I like the LF less fittings less room.
I use a home made system and a B164.
I did the LF9028 on my last oil change. No modifying needed. It goes right on just like the original.
Hope this helps.
Centrifuges are the most efficient. They remove down to 1 micron. Hence why they put them on the big compressor motors in the oil / gas industry.
https://www.dieselcraft.com/
If I were to upgrade the filtration on my trucks it would be one of these.
Let me guess. You haven't upgraded because the cost is significantly more than the benefit.
No, I don't see the necessity for it. I just use amsoil and delete my trucks. i change oil every 25000kms. Always plug them in. Winter fronts. Do good break in periods on the motors. My 07.5 I sold in January had 300000kms on it and it was mint. Didn't burn any oil and I started to change the oil once a year which ended up being 30-40 000kms. I had an Espar heater on it which helped a lot.
Brand of oil means nothing when it comes to filtration. If it did, why would there be a filter at all? Just pour in some Amsoil and drive? I don't think so. 25,000 KMs is only 15,500 miles. Class 8 trucks with bypass systems go 100,000 + miles between oil changes. I wouldn't expect an engine with 300,000 Kms to burn any oil, 186,000 miles is nothing with a modern engine. My original engine didn't start using oil until I was over 500,000 miles, and that was before I discovered bypass filtration. Oil of choice? Whichever was on sale including lots of Wal-Mart Supertech. Filters of choice? Fleetguard Stratapore.
Consider this a thread revival. After doing a search for oil bypass filter, this thread was the first to come up. I have already found useful suggestions in previous posts, namely the use of Fleetguard LF9028 oil filter.
More that one person has mentioned the building or fabrication of a bypass filter system. Where would I start my search to build my own 2 micron oil filter? I understand the concept of pulling oil from the current filter housing and putting it back in the engine oil fill tube. Any suggestions for suppliers of a homemade oil bypass filtration parts would be greatly appreciated.
1 - 17 of 17 Posts
