need to load test your batteries with a real load tester. same machine can be set up with the amp clamp on the charge cable and will show if it's charging
Check the fuse?The load test checked out good. Took the new alternator back and got a new one and that fixed the problem. They sold me one with a bad bearing the first time. Thanks for all the info!! Now just have to figure out why my left light only has 8 volts!
