So i noticed a slight grind/groaning noise at idle that seemed to come and go while idle rpm stayed dead on 750. pulled the belt and started truck and the sound went away. Alternator is making noise while spun by hand and i also noticed that it seems to have a bearing and one way clutch in the pulley. lots i see online have a pulley that id imagine is keyed on the shaft and held on by a nut. any advise on what you guys think i should go with for an alternator is greatly appreciated! i deleted the passanger side battery and grid heater due to a broken battery box and was having trouble locating a replacement so i went with the cheaper option of deleting the battery as a whole. thanks for your time in advance
