Is there a way to program mileage? And how is everyone changing tpms
Program mileage???
If you swap clusters to a nicer one there is a way to make the hours/miles in the cluster match your truck. Most of the companies selling the 7” EVIC upgrades online include programming for the cluster to match your trucks data with the purchase.Program mileage???
Im curious if this will end up happening. I know there are some serious legal issues with changing miles in some states. I have swapped clusters in two vehicles over the years and had to sign a legal disclaimer for the state in both instances.Apparently (just forgot his name) said in the next update he will give us access to change engine hours. There was a little discussion about if he can do that then changing mileage could also be enabled. So who knows we may have the ability to program mileage and hours if you do the premium cluster swap
Edit. Over in rf
In the end, its your truck, you do what you want, I am not advocating either way as I believe there are circumstances where it should be allowed. Im more just curious about the legal implications of this.
As I stated in the post above, it is possible to reset the cluster HOWEVER the ACTUAL values continue to be stored in the ECM and can be read by the dealership. I do not believe that any companies other then the dealership have the ability to change the stored hours and mileage in the ECM.There are companies that can reset mileage and hours with no questions asked no paperwork needed. People are doing the premium cluster swap all the time. I did it on my 2015 and may do it on my 2018. The mileage is stored in 2 places so it's a easy check to find out if the cluster has been messed with. So if Alexey gives us the ability to change mileage and hours ourselves he'd be saving the people who want to upgrade (and those who are scammers) clusters time and money.
I didn't say that dealers could program clusters. What I said is no company other then a dealer would be able to access and/or the ECM engine hours and mileage. They would have to be able to program a new ECM to reflect the correct hours and mileage. My whole point is that there are people who would try to reset mileage to increase value, but it is not difficult for the dealer to read the ECM and get the true info.I don't think the dealers have the ability. They can't program mileage in the clusters
Every thing you say is true, however if I am looking at this low mileage truck and suspect anything I will tell the dealer that I want the info checked in the ECM and I WANT to be there when they do it or no deal! They will check it if they want to sell the truck.Adding the ability in Alfa to change the cluster is a BAD idea. That just opens the door to fraud. Just send it off and get it done.
Yes the dealer can read the ECM but can Joe the consumer that is looking at buying a used truck? And how many dealers are going to look at the ECM to double check? ...None. They are going to look at the cluster and go, Wow, only 20K miles on this truck, I'll give you top dollar. And then some unknowing consumer will pay top dollar for this "low mileage" truck.
