@ckessel
I'm starting to have left knee issues - this getting old ain't for sissies, but it sure beats the alternative! My knee starts to ache after about the fourth light in traffic, with the DD clutch.:S: And that's with shifting to neutral and letting the clutch out at lights.
Your truck must be a 2wd for the cost to come out around 5K - it's about 1K more in hard costs for a 4wd.
I've been studying and researching the swap over the past year, and have recently committed to a transmission - it's a 2200RDS from behind a ISB6.7 in a medium duty truck.
For those that say "why an Allison? a 48 is better", not all of us are into street machines, drag racing or sled pulling with modified engines. If you're happy with your four speed, great!
We typically bought our trucks to tow, and when towing in the mountains, the 47/48 doesn't cut it.
I've found that my early G56 has almost perfect gear splits across the board for towing, except for the fact that it doesn't have a seventh gear.
Running empty down the highway at 2000 rpm at 60 mph with a Cummins is ludicrous.
Turning 2500 rpm to keep up with traffic on the freeway is insane.
The 68RFE has very similar gear splits to the G56, with it's 5th gear pretty much matching the G56 6th. I've found one vendor with a standalone 68rfe controller calibration to put a 68 into a pre-'07.5 truck. But he doesn't support an exhaust brake. This makes it a non-starter for me. Plus then there are all the know 68RFE issues to be dealt with.
The Allison is not with out it's challenges:
- 5th gear has the wrong ratio in my opinion - it should be around .8:1, not .71:1
- due to it's massive internals, and clutch to clutch shifts, it will never be the fastest shifting tranny - that is a given. If you need fast shifts, spend your money on the 48.
- The electronics package to do the swap is expensive - count on 2K minimum, unless you are willing to cobble together a harness, TCM, TPS and figure out how to program it all. Then you might save $500.
- Commercially available engine/trans & trans/transfer adapters are not cheap.
But the Allison can be tuned for lock to lock shifts, both up and down. I understand that that is the typical medium duty calibration, so it likely won't be a smooooth as a Chebby! But look at all the medium duty trucks and RV's out there - Ford, GM, Isuzu, etc... The one thing in common is most/all run Allisons!
My GCVW with the 5th wheel on the back is 19,000 lbs.
The 2200RDS Allison is rated for 26,000 lbs GVW&GCVW in medium duty trucks, day in, day out with a life expected to be north of 500,000 miles. Try that with a 48 or 68RFE.
I try to fix things once and fix them right! YMMV!
When my ball joints went, I put in Carli's.. When my wheel bearings went, I put in hubs.. When the steering box was done, I put in the 6 bolt modified 5500 box..
Regarding the shifter - I don't particularly like column shifters, so I am researching console shifters. What I've found so far is the shifter detent comb on the 6 speed Allison has 7 detents, but some say the last one is not used. Shifter positions are - P,R,N,D,M,1 - but I suspect that that is the configuration for a GM 1000 with TapShift capability. The only console shifter I've found that is specifically for the Allison is the Art-Carr/Winters unit. Or Allison units on EBay
Hope that helps.
