1 - 13 of 13 Posts
I am looking for input on a good, all around alarm system. I don't want to spend an outrageous amount.
One question I did have is with an aftermarket alarm system, can you still use the turbo timer on the Edge?
I've got a Viper 5901 2-way alarm remote start, and it is sweet. It communicates with the truck so you can tell if it started and it pages you if someone breaks in. It's got a wait to start timer so my Edge can clear codes. You can still use your Edge turbo timer also.
Cool - thanks!
Is the 'wait to start' timer something like 10-15 seconds?
You can program it to however long you want. I've got mine set to 11 seconds. It gives the Edge just enough time to clear codes.
I have the compustar pro, which has the same features as the viper, and also has a turbo timer, kind of useless if you have the edge, but none the less it has one.. one feature that it has, is the tap thing on the windshield, you can tap a code in, like moris code, and it will unlock your doors, as long as you get the right tap sequence you program. Check out compustar website, and go to compustar pro under products, it wil give you all the details you need
were there any problems installing these or were they plug and play?
Thanks Robert
installing a starter alarm on the 6.7 is a PITA i recomend you bring it to an installer
It is a huge PITA to install one of these on a 6.7 as Mattiac has said above due to the canbus and having to bypass alot of crap. It's not as easy as an older vehicle.
Do either of you have a wiring/suggestion/ location sheet? I have recently got a Clifford 50.7x, called DEI to try and get one, but they were cocky d*cks.
I need some help.
Thanks..... Rhyno
I need some help.
Thanks..... Rhyno
Anybody?....Anybody?
no man.. sorry
Regen? What's That??
Reactions: Rhyno
Thanks for your help.
-Rhyno
1 - 13 of 13 Posts
