Contact Eric at Vulcan performance... He's can set you up with the fittings...anyone running airtex E7153 as an "on the frame rail" application? If so, how did you defeat the OEM banjo fitting on the inlet side of pump?? I want to use mine with 1/2 in in and out barbed fittings. got to be a way. thanks.
