I just ordered an airdog 150, i was wondering if it were possible to install it in the engine compartment. i know the ideal place is as close to the tank as possible, but will it cause damage if its under the hood?
My opinion, go for it. If it works out just fine for you, then all the nay sayers can come up with other reasons that you shouldn't have done that. :thumbsupim going to attempt to mount it under the hood, with a 1/2" line to the tank, i dont think it will cause too much of an issue stressing the pump, ill check what its putting out for pressure when its in the engine bay and let you know.
