1 - 4 of 4 Posts
I just got done installing my ADII 100 Now I have fuel coming out of the factory supply line (its not coming out of the tank or any of the lines that are hooked up for the AD to operate) that goes to the DODGE fuel filter. What did you guys do with the factory supply line? Should I drain the factory fuel filter? Fuel is draining back toward the fuel tank. Not fuel coming out at the factory fuel filter housing, all I have is a plastic line cap pushed into the factory CP3 port on the filter housing so it is by no near air tight yet not fuel out that side just the factory fuel supply.
mine did the same thing, drain the filter and it will stop
Reactions: neeltburn
Thanks Man, did it stop right after you drained the old filter? and did you plug the water in fuel sensor back in?
Filter is drain.. hopefully its good to go now?
1 - 4 of 4 Posts
