I wound not fool around with the stock pump and pick up, Dropping the tank is not really hard to do, use wait in till you have a 1/4 tank and use a trany jack to support the weight. The hardest thing on mine was getting the quick connects undone, If you have a long bed? your going to have to loosen the carrier bearing on the rear drive shaft to remove the front tank strap.
Once you have the tank down, pick it up and support it on a set of saw horses, in the same location the tank straps sit. That way you can cut the draw straw to length. The tank is plastic not metal, so drilling the hole is pretty easy! Just follow the instructions, there is a lot of photo's to guide you through the install. You need to have the 1/2 line running from the draw straw to the VP with this pump, if your not up to the install, just buy the 100, as it's designed for the stock lines :thumbsup
