On my 2000 cummins 2500 the air vent will no longer blow air onto my feet nor face vents. Its will only blow on the wind shield.
just before this happened the blower motor wound vibrate the heck out of the dash. I found a plastic like flap in the motor being the cause of the vibration. I believe that that flap controlled the direction of the air. But I can not find where the flap goes/where the valve is to direct the air.
I believe that the flap could still be there just not functioning at all. I can not feel any air from the front or bottom no mater where the dial is pointing. Pleas help its hot and all my air is doing is cooling the wind shield!!!
Thanks,
Chris
Thanks,
Chris
