Have a '06 MegaCab 5.9L
Problem: When I turn the air on, doesn't matter hot or cold, the air is barely coming out of the vents. I put the selector switch in any position, either blowing in the cabin, on the floor, defrost, etc. and there is barely a trickle out the vents. I put the fan speed on max and same result - only a trickle. Sounds like it's blowing all the air into the dash but not out the vents.
Any ideas? :CRY:
i dont know squat about newer models, but my 02 had this, after i knocked a vacum line loose installing the edge, maybe it is a vacum problem that isnt channeling the air where it needs to go thru the proper vents
Shiftin Fool
yup sounds like another blend door broke. its a very common problem issue!!
Is it a do-it-yourself job or would it be best to take it in? It's under warranty, but I would rather buy the part myself rather than wait a week until I get it back.
I would have it done under warranty. It should only take the stealer about a day....it would take you the better part of a weekend - at least from what I have heard.
If it was me, I would not want to rip out the whole dash to fix it myself, when Dodge can do it free....:thumbsup
Found the problem. It was the recirc door. Pulled the blower motor, reached up and one twist, out it came. Blowing a lot more air now that the door isn't in the way. Think I will bring it in and have it done while in warranty. Just now I don't have to rush to get it done.
Thanks to all for the input! :beer
