1 - 3 of 3 Posts
Curious to see what pressure you guys are going with for 35" tires. I've got 35x12.50/17s on factory wheel. Been running 50 in the front and around 45 in the back. After around 5k or so miles being put on the new mastercraft coursers, I can see by the tread wear thats too much pressure. What should I be running in the front and back. Trucks almost always empty. Thanks
Try 42psi all around.The ride won't be as stiff.I'm assuming max psi on your tire is 50psi?
Yep. Max psi is 50
1 - 3 of 3 Posts
