Alright, not anything terribly awesome, but here's what I've done so far:
Napa wanted $80 for a filter and would have to order one in, so I found one (but smaller) at Advanced Auto for $45.
I then went over to Home Depot and got a 3" 90* elbow for $4.
I took off the stock air box and drilled a 1/2" hole in the middle of the elbow bend. Be careful with PVC as everything sticks to it.
Pre-drill two 1/8" holes on either side of the 1/2" hole and you can use the stock screws to fasten down the sensor.
Insert the sensor and screw her down tight, put your filter on one end and clamp, the clamp the other end into your intake. Easy Squeezy Lemon Peesy.
The only thing I'm concerned about is the fact that the filter is smaller then ones I've seen before. But with my silencer ring MIA, and the baffles punched out of the intake tube, this thing sounds like a 747 taking off! Pretty cool.:thumbsup:
