So I changed the hose on the fuel return line few days ago because it was leaking. I started the truck, it worked for few minutes then died like it run out of fuel, but it has a lot of fuel in the tank. I unscrewed the overflow valve a little bit on the injection pump and started to pump the fuel manually with the button that's on the mechanical lift pump, and I saw bubbles coming out of loosened return line.
My question is where it could suck air from?
I also happened few months before when I was driving and it died on the road, pulled off and started again with about 10 seconds of cranking.
I though it might be bad fuel sending unit that I replaced from another truck? I think it's in good condition.
Could be a problem with an injection pump? Any seals that I have to change?
:confused013:
:confused013:
