If I understand it correctly, a lot of smoke is indicative of unburnt fuel, right? Low amounts of smoke at high-load or full-throttle applications would seem to indicate maximum efficiency or an ideal fuel/air mix. For me, that means "rolling coal" is a bad thing, so I want to minimize smoke production, even at high-load, full-throttle applications.
I'm trying to work out in my head how I can tweak for more power without wasting fuel and dumping my efficiency in the toilet.
Turning up the star wheel 'til you get smoke, then backing off a touch, that makes sense. If you get too much smoke, just back it off a touch more. I get that. But let's say I increase fueling by changing the fuel plate or installing bigger injectors and get a lot more smoke, does that mean that I need to provide the engine with more air? A more efficient exhaust manifold can help the turbo be more efficient, so I assume that provides more air. A better intercooler increases air density; does that let the engine use fuel more efficiently?
Once you get past those things, if I've already got a high-flow intake installed, does that then mean that you need to upgrade the turbo?
I guess I'd like to go as far as I can, efficiently, without changing the stock turbo. What kind of HP/TQ numbers could I see, maximizing fuel/air efficiency? Or am I completely wrong about this whole thing?
Opinions? Facts? All are welcome, and thanks. :yourock:
