:ditto::ditto:
i have a short box, had to mount it on the outside of the frame under the drivers door area...clearly visible standing a few car lengths away from the left side but if something comes up and bashes it that high on my truck, then that thing will be the LEAST of my worries! :thud:Not 100% sure on the II cause I've got the 150 but it's pretty simple to install. The II comes with a replacement sending unit so you don't have to drill the hole for the drawstraw which was the hardest part of the 150's. But all you'll have to do is pull out the old unit and throw the new one in so the choice of dropping the tank or pulling the bed is just preference.
Mount the pump itself as close to the skid plate under the transfer case as possible to protect it from the road, but if you have a short box not sure exactly on mounting unless they started offering the plate that turns the perpendicular to the frame.
Put oil in the hose before pushing the fittings in to make it easier and make sure the hose is flush with the plastic washer.
It's nice to have a garage to work in, but if I can install one on dirt with 20mph winds beating me around I'm sure you can handle it. :thumbsup:
in your case, get a draw straw V and a raptor150...and maybe a couple of those fittings airdog uses for the injection pump so you can still use your stock filter/water separator with the larger lines. be cheaper since you already have the bigline kit...Think I'm gettin a 150. But not really sure which will be better for my set up. :confused013: Guess I'll have to do some research.
I'm gonna have to do some research. Never even heard of a draw straw V. :confused013: What is it and where can I get it?in your case, get a draw straw V and a raptor150...and maybe a couple of those fittings airdog uses for the injection pump so you can still use your stock filter/water separator with the larger lines. be cheaper since you already have the bigline kit...
