Status
Not open for further replies.
1 - 9 of 9 Posts
I have a 2014 RAM3500 dually with 6.7L engine and megacab and 6' bed which tows a 42' 5th wheel. Recently fitted a 40gal under cover refueling tank with pump
Wanting an air compressor which is 175PSI and can inflate tires, a 14' dinghy fast, and can undo wheel nuts for a tire change.
Does anyone have suggestions for brands which are good to mount (ideally) under the RAM to maximize the space?
Thank you
Might not be exactly what you're looking for but this is the system I used to have on a previous truck and will be soon making its way to my new rig. I've run plenty of air tools off it changing times and such.
I know it can be found cheaper but that was one site I knew that had the complete kit. If I'm not mistaken, Viair is also a site sponsor and might give a deal on kits for members.
The above tank has a ton of air and the one pump comes with everything you would need to hook to tank including pressure switch. The tank has a ton of ports which may come in handy if you plan on running airbags, train horns ext.
I run a 3500 watt inverter with a 150 psi pancake 6 gal air compressor
air compressor from home depot $100
inverter from Ebay $150
1 - 9 of 9 Posts
Status
