Does anyone have an aftermarket trans cooler that has enough flow and fits in the same location as the stock one without major surgery? If so where did you get it?
I found that increasing your oil volume does more good than a different cooler. Put on a ATS deep pan or make an auxillary storage tank and plumb the lines into it for additonal storage (that's what I did, the poor man's deep sump)
Problem is the fins on the stocker are all smashed. And the trans is blown so I don't want to have to flush out the old cooler. I'd buy a stock cooler but...
it's around $300 with shipping and more importantly it's backordered until sometime in June. With the bankruptcy I figure that could be even longer and I don't want the truck to sit around that long.
Salvage yard? Radiator shop may be able to recon it then reinstall? Parts may not be available for some time. All the back orders have to be filled before you can get in line once production starts again!!
flex-a-lite makes a direct replacement for the stock one with -8AN fittings when i swapped out my tranny to this BD one i did my Flexplate, torque converter, tranny, then ran stainless steel -8AN hose and fittings from the tranny to the remote filter (that came with the thing from BD for "warranty" BS) then to the cooler back to the tranny. I skipped running it back to the heat exchanger by the turbo.
locked up and cruising.... never much above 105 degrees in the pan
crusing around town it traffic. constant shifting. 150 in the pan
lugging up logging roads with my dirtbike in the back, in 4 hi flinging goo, around 160ish max
Dodge Cummins Diesel Forum
