I am going to purchase a set of aftermarket wheels and was wondering what "offset" would work best with the 17X35BFGs and 2 inch level kit. I want a little wider stance than stock. :$:
I have the same rims and I myself (Black) have to buy some fender flares. I'm getting a lot of road grime and tar on my body! Fender flares are cheaper than body work I suppose..yeah, im getting fender flares though
they stick out about 2" and im getting 2.5" flares
if you are going to run 35's on just a 2" leveling kit you pretty much limited to the 5.50(+or- a very small bit) back spacing. i have 20x10 rockstars with a 4.5" backspacing. I went with them because i wanted that wider stance. but i was limited to 33" tires on the 2" leveing kit. Those still rub.I am going to purchase a set of aftermarket wheels and was wondering what "offset" would work best with the 17X35BFGs and 2 inch level kit. I want a little wider stance than stock. :$:
no less than 5" something like 5.25 back spacingI have a 2005 3/4 4x4 lb and want to put 18x9's on it, but don't want them to stick out past the fender. Does anyone know what offset I need. I like the rockstars of course and the diamo karat I8.
my buddy has a QC short bed with 6" and 37's, i dont like it. looks like a skate board with off road tires on it. (i hope he does not see this) i think the 35's will look the best on a 6" lift. personally i would go with a 4.5 back spacing. i like the wider stance you get from it and you will have no problems with 35's and a 6"lift. you will more than likely rub with 4.5" back spacing on the 37'sI have a six inch lift and I am looking to put 35x12.5 R17s. After speaking with a few different wheel companys they suggested 5-5.5. Does anybody have pictures of a truck with a six inch lift with 35s? I am just carious how it will look or should I go up to the 37s?
