1 - 13 of 13 Posts
Wondering why Mag-Hytec, Goerend, etc specify that only a fibre gasket be used with their trans pans. Anyone here know why?
I have the Mag-Hytec pan and there's always some leakage with the fibre gasket. Never had any leakage with the stock pan/gasket!
Also, the hex bolts provided with the Mag-Hytec pan are a pita:frown2: compared to the stock standard bolts.
Because, there’s no lateral support from the aftermarket pans. I have a B&M pan with a silicone lined gasket that doesn’t leak at all.
Re "lateral support", are you referring to the "lip" on the stock pan?
Apparently some are using the stock Mopar OEM gasket with these aluminum pans - with no leakage problem! Anyone hear otherwise?
The lip or on our trucks there’s no lip but there is a bit of a ridge that runs down the middle of the surface.
I prefer Lubelocker gaskets on aluminum pans, and the rigid factory gasket on steel pans.
Both the above gaskets are reusable.
Whatever you do ,, do not use the thick oem gasket on one of the huge alum aftermarket pans.
Bolts are too short , bad times for the trans threads . dont ask.
Bingo! I think you've answered my question. That thought never occurred to me. Thanks for the reply amigo!
Fiber gasket here no leaks. Most people over tighten the bolts which crushes the fiber gasket causing leaks. 10ftlbs is all ya need
Discussion Starter #9
Thanks! Too bad the dealer list on LubeLocker's web site doesn't work - I need a gasket today!!
$40.16 incl tax/shipping. That's a no-go for me. Seriously, $40 bucks for a gasket?
$25 at Summit.
If one's counting to save $ - then, as mentioned above, 10 lbs-ft on a DRY fiber gasket does the trick just fine.
You should go back and retorque the fiber gaskets after about a week. 10-12 ft lbs... No leaks, and maximum transfer of the pan's structural rigidity to the case (which is one of the main reasons for running an aluminum pan).
Ah, since I don't expect free shipping on a low dollar item, I generally ensure I order enough product to squeak by for "free shipping".
1 - 13 of 13 Posts
