1 - 15 of 15 Posts
Corona, CA - advanced FLOW engineering (aFe Power) releases the all new Momentum HD Sealed Air Intake System for the Cummins, Duramax, and Power Stroke Diesel Trucks.
The Next Generation of Intakes: The Momentum HD sealed air intake system is designed using the most up-to-date engineering tools and techniques to provide you with the perfect blend of power and protection. This intake system is premium in every way. From the one-piece sealed housing with a built in sight window to the massive 1,000cfm air filter to the premium hardware.
Unique One-Piece Housing: The smooth one-piece sealed housing with auxiliary air scoop is used to eliminate the use of multiple-piece housings and ensure the coolest air intake charge available. A urethane plug is also included for those cold weather applications where you want to block the auxiliary air scoop. A large, clear sight window is used for a hassle-free filter inspection.
Huge 10-Layer Performance Air Filter: The Momentum HD is designed around a massive 360 degree radial flow air filter with 10-layers of progressive cotton media producing 99.47% cumulative efficiency. The unique air filter to housing interface (patent pending) allows for maximum filter size which increases the available air volume while simplifying the installation process. The air filter is wrapped in reinforced metal providing maximum strength to prevent filter collapse
Premium Hardware: Premium stainless steel T-bold clamps and a 2-ply reinforced silicone hump coupler at the turbo is used for strength and durability while also providing the most secure installation available. Momentum HD intakes are designed with fewer parts for a quick and simple installation.
If you have any questions or would like more infomation please feel free to contact me either on here or by phone at (951) 493-7134 or (888) 901-7693
Steven
aFePower
Any word on when this new intake system will be available for the Dodge trucks???
August 2014?
I believe these are out now and available!
I really like it. Fit very well, quality construction and looks really good. Turbo sounds good through it, silver bullet 62. I'm very happy with it and would certainly choose it again and recommend to anyone else looking for an intake. The truck didn't have a stock airbox on it when I bought it so I can't compare it to stock.
Anyone else?
1 - 15 of 15 Posts
