if you go with an oil filter...like the AFE PG7 i have, use an aerosol type oil and lightly mist it. as long as your not drowning the filter in oil, you wont have problems. its not that difficult..............Like mudn_1 said run a dry filter and if you are worried about small particulate then run a pre-filter over it and you will be good to go :thumbsup. I am running the AFE Stage II Pro-Dry and it is an awesome filter :woot:.
:agree2: Same here. I have both filters, but run the oiled for daily driving. :thumbsupif you go with an oil filter...like the AFE PG7 i have, use an aerosol type oil and lightly mist it. as long as your not drowning the filter in oil, you wont have problems. its not that difficult..............
i used to run a BHAF but around here they are $70!!! :thud: and i found myself replacing them twice a yearShoot... I'm still running my first BHAF and got 60K miles on it now and the filter minder has moved yet... No need to clean, no need to oil, etc... Just works!opcorn:
I got to admit the outerwears extends the life of any filter alot! :w:
Hmmm... how about $39 a filter???i used to run a BHAF but around here they are $70!!! :thud: and i found myself replacing them twice a year
actually i think its called an exhaust leak at the downpipe :T:Hmmm... how about $39 a filter???
BHAF Air Filter
And my filter has the filter minder in it from my stock air filter box... 4 years old and still has moved the minder yet...:rof
I think you changing filters too much...:w:
Hey guys how often do we have to change out the oiled filters? I heard we have to clean and reoil at 20-30k. But these things have to get worn over time right?
