101 - 106 of 106 Posts
Discussion Starter #101
Weird, I have a napa 200* in my truck and have for months and it's been fine. Was the same size as the 190* stant I pulled out.
Don’t know how well it shows up in the picture. But that’s a old stant vs napa stainless steel thermostat. The regular looked exactly the same but wasn’t a shiny. I had to center it in the thermostat mount on the head, where as the stant and cumming just slipped right in and fit nice and tight . I had high hopes for that napa thermostat. I noticed the opening on the top was bigger thought will it should flow better once it opens . But after having two go bad in a short amount of time ... I just switched to a cumming . Time will tell how the Cummings Thermostat holds up.
TECH SPECIALIST
Is that napa one a 58mm OD flange? Notice the flow area is greater than that of the 190*f stat...
Discussion Starter #103
Both are from napa. The one on the left is the stant and the right is the one that replaced the stant. When I looked at the napa web site that newer smaller design is all they showed . They Are both rated for 190. But the new version had 192 stamped on it . And yeah I noticed the area where the coolant flows was bigger on the new one . I had hopped it was going to be a upgrade from the oem design, but after going through 2 in just a few short months.... yeah I went to cumming .
I am on the list for an AFE radiator. I was thinking of converting the coolant to Evans when I do the install. I think it has a higher boiling point and lower surface tension vs water/antifreeze. I wonder if anyone has tried this product in their truck.
Jeff
Discussion Starter #105
I’ve heard about the Evans coolant . Sounded good on paper, but I’ve also heard a lot of people complain that it cause there cars to over heat. Don’t quote me on this , but I think even J Leno had problems with his cars over heating with the Evans coolant .
