1 - 4 of 4 Posts
97 12v
Put the medium spring
Truck had zero low end power
Took out went to stock. No issue
Tried again and Wouldn't start
Star wheel cranked to back of hosing smoke screw was just touching.
Old spring/original spring zero issues when reinstalled
Screw the smoke screw in farther. If you have the afc slid all the way towards the firewall, you are not getting enough fuel to light the turbo.
AFC is pushed twords front along with the fuel plate plate.
I'll screw the smoke screw in more.
Thanks
Did you try pressing the accelerator a little while trying to start it? When I first got my truck (still had the stock AFC everything at the time) the truck wouldn't start without giving her a little throttle. I've since changed AFC spring, installed flat washers, ground the fuel plate (all the normal cheap/ free stuff) and adjusted the idle. Now it starts great with no throttle input needed.
1 - 4 of 4 Posts
