1 - 3 of 3 Posts
Tried to open up AFC for the first time today got the two 8mm bolts off no problem along with the screw and the break off screw then I go to lift the cover off but it won't lift off everything on the outside is clear something on inside is holding it up. It lifts up like a 1/2in and wiggled around just won't pop off. I just put it back together and truck ran fine.
So why won't it come off
You probably got this already, but the fuel shutoff solenoid bracket has 3 bolts that hold it on, 2 on top of the afc, and 1 on the back of inj pump.
1 - 3 of 3 Posts
