does it smoke that much even with stock charger and sticks?adrenaline with the adr3000 tune WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!! lots of smoke
x2:thumbsupSmarty smokes easier, quad smokes more. I've run them both and buy far the quad will out smoke the smarty in terms of quantity and thickness. In terms of ease, smarty wins that. With the smarty it takes half the throttle the adrenaline does to get the same smoke cloud but the adrenaline will dump more of it.
And I agree with graphic man, don't buy a box just for smoke. Buy it because it suits your needs.
As it should right?Smarty smokes easier, quad smokes more. I've run them both and buy far the quad will out smoke the smarty in terms of quantity and thickness. In terms of ease, smarty wins that. With the smarty it takes half the throttle the adrenaline does to get the same smoke cloud but the adrenaline will dump more of it.
What he said. It's a mean stack.stack the adrenaline and smarty. its what i plan on.
Smarty is a programmer. But yes, the quad should smoke more because it adds more fuel than a smarty could even dream about adding. You shoulda see the cloud with the 3000 tune on the quad and the 200hp injectors I'm running. It was taller than the truck by the time the turbo lit off.As it should right?
you are comparing a plug and play box to a wire tap box.
u need the 7x12'sSmarty is a programmer. But yes, the quad should smoke more because it adds more fuel than a smarty could even dream about adding. You shoulda see the cloud with the 3000 tune on the quad and the 200hp injectors I'm running. It was taller than the truck by the time the turbo lit off.
We'll see what the bank account looks like when I get back from bama.u need the 7x12'seelout
