if you are installing a EGT probe, put some heavy grease or vaseline on the drill bit before you drill into the manifold. that will help keep the metal shavings from dropping in there, and be a pain to get out.
How do i make sure i have a good connection?Make sure you get a good positive connection with the wire tap or you won't get all of the power it has to offer.
