1 - 11 of 11 Posts
Calculate the following:
Adrenaline lvl 10 + stock injectors =A
Adrenaline lvl 3 + 150hp injectors= B
Adrenaline tune = 3000G
Does A=B??:confused013:
Thoughts?
Comments?
Opinions?
Discuss.
u mean like lvl 10 adrenaline = about let say 250hp injectors without the adrenaline? I think its impossible because the programmer changes every aspect of the electronics..
would i yeild the same hp/tq numbers (~350hp ~940tq) if i were to get 150 injectors and run the adrenaline on 3 as i did with stock injectors with the adrenaline on 10
no because you can get alot more with level ten and 150hp injectors.
I dynoed 390/823 with stock turbo and trans and 150ddps and quad adr
Mule Barn Proprietor
id say so.
I dynoed 350 with a xzt+ and 150s. (xzt+ = ADR level 2.) Whats a adrenaline on 10 dyno with stock injectors........??? 350
I bet the torque is a good bit higher with the injectors
id say so.
i got 353 with stock injectors on lvl 10. i'm trying to get to the same power level without the wire tap
maybe 200s would do the trick?
Discussion Starter #8
that's what I'm working on figuring out. I'm thinking with the extra 35hp(maybe) i get from the adrenaline running on level 3 with timing will and 150s as stock on level 10 which is suppose to be 180 with timing. but i don't want to get real hot because I'm not to the point of adding a second turbo in all, especially since i have a 2.5 month old son. i do have an HE351 to put on if i can get off my lazy duff and put it on. i planed on 351 over a s400 series turbo. but need the time and $$ to do it. i dont plan on huge numbers(yet) just want a good setup to make people second guess them self and relize they are playing with some fire
Discussion Starter #9
Discussion Starter #11
yeah, thats exactly what i was showing you.:confused013:
yea, i was agreeing with you. that was the exact information i was looking for
1 - 11 of 11 Posts
