Replacement Hinges
LMC Truck sells replacement door hinges. I purchased them and I am trying to see if any one has replaced them. I'm hopping to find some instructions as Dodge expects us to replace hinge assemblies and LMC Truck did not supply any instructions.:thumbsup:
Well, this morning (Aug 8, 2010) I finally got around to attempting the hinge pin repair. Not gonna be easy, I drove out the upper pin, found both bushings worn throuogh and pin is worn. The supplied pins from LMC do not fit in the existing holes, the new pins are larger dia but shorter. The factory pin has a larger lower od than its upper OD, so....I will have to drill out the existing hinges. My expectation was a replacement pin, not ones requiring hinge modifications. Gonna have to take doors off.
