i am in the middle of adjusting my apps and i am trying to figure out what to set the volts at because on my white tag it says 0153RF does theis meen .153 or 1.53?? the other longer number on it fell prey to sum brake cleaner trying to clean the dirt off....
Cummins Fanatic
That sounds too low. Mine WAS at .157 but the tag called for .571
Yea i think thats way to low. See were you are at, but mine was at .3?? and it was supposed to be .609 . I think most r suppose to be between .570 and .610
Most everyone I've seen has been up around .500 volts or so. You can start there and see how it runs. The worst that can happen is it's too low, engine defaults to idle and sets a code.
Mopar1973Man.Com
Brake cleaner, carb spray, laquer thinner, are all mean cleaner and tend to remove label and the ink on labels...:thud:
