Possibly check your air filter if its wet that may cause a restriction
Yes, had that message at start up one time and went away and haven't seen it since. How many miles on you truck?Anyone had the message "Active Airbox service required. See Dealer" message pop up in the EVIC? My truck just started doing this last week. First 14k miles were trouble free. The message pops up upon startup, it intermittently does this. No check engine light comes on. A couple times it will keep the message stored in the EVIC menu, and other times it disappears. Going to take it into the dealer on Friday.![]()
Update: Got it into the dealer and got the call back a little while ago. Apparently this is a known issue and Ram is saying not to replace the Airbox, the problem is being looked into by the engineers and to check back in a couple months to see if they have a solution posted.
Started doing it just after it rolled over 13k miles. Has 14.5 on it now, no rhyme or reason to it giving me a message. Only has done it on startup.Yes, had that message at start up one time and went away and haven't seen it since. How many miles on you truck?![]()
Nothing as of yet, ours hasn't done it yet and is almost at 19k miles.Mine did this today, any update?
Mine did it last week, with 7100 on the odo.I had the message flash today on start up. No letter icon or message saved. Just flashed on the screen. I am at a little over 6K on the clock.
