If I unplug my ABS module can I still drive the truck? Also, I heard there is a possibility that the ABS module has been recalled on the 04 model trucks. Does anyone know where I can find that information?
You can drive it with the ABS unplugged. It'll likely throw a code, and of course the ABS won't work. For recall info, call your local dealer with your VIN, they'll be able to tell you if there are any recalls or TSB's for your truck. HTH
On mine, the relay in the control box is stuck. I unplugged it at the ABS control box. It makes the ABS and brake dummy come on, and will toss two brake codes, but the brakes work fine, and all my gauges were otherwise unaffected. Of course mine is a gen 2, so it might be a little different on yours.
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
