Ok so I have 1995 12v 5 speed and the ABS light is on and when I was working under the hood the other day I noticed that there is no relay for the abs
I was just wondering if that is needed for the abs system?
I don't have one to try it but i don't wanna spend that money for one if I don't need it.
Thanks in advanced
So you think ill need to put a relay in it and maybe the abs light will go out unless there's another problem?
This came up in another thread recently, the ABS relays are only used with 4-wheel ABS... if you have only rear-wheel ABS, you won't have all the relays/fuses.
Jim
Oh really then I'll get a relay and see what it does. There not that expensive anyway
