1994 Dodge 2WD, 5.9L
My ABS and Brake lights are on all the time.I have good brake peddle.
If I unplug the wires from the Low pressure vacuum switch, the lights do a self check and go out as normal.
Do I need this Low pressure vacuum switch for anything else in the system other then ABS system?
Their are three wires to the switch can they be jumped ? I checked the switch with vacuum pump and Ohm meter and its always shows closed connection with vacuum On or with vacuum Off?
Dealer wants $100.00 for new switch!!!!!
:help
:help
