im about to buy my first diesel its a 96 ram 2500 with 122k miles. when i test drove it i noticed a shudder from what i thought was the trans.it only happened once and other then that the truck drove real nice. when i got back there was a small leak coming from the back of the driveshaft any ideas what this could be?
were you taking off when you noticed it? turning?
taking of straight ahead carrier bearings can cause that as well as u-joints. if it does it taking off and turning it probably just needs the rear diff oil changed and new friction modifier added.
could be a lot of things
auto or manual?
leak from drive shaft? you could be more specific. 4 wd / 2 wd? etc....
take it for another drive,
if your unable to diagnose yourself you may want to have a mechanic check it out
i noticed it when i was slowing down. i was thinkin it was the u-joint or carrier bearing too but im not the most mechanicaly inclined person haha. its a 2wd automatic. im going back for another test drive tomorrow and to bring it to a mechanic but figured i might as well ask here first to get a rough idea of whats wrong
