05’ RAM, D&J Performer, 150% w/ 12mm Exergy, 64/80 Turbos, Billet Everystuff Trans Built by Me
Does anybody have the part numbers readily available for the timken bearings? I was reading that they changed to a better bearing on the pinion in 2011. I've rebuilt it once with a AAM kit and it didn't last long " The howl is back! "
Didn't last long? Define that.
The AAM OEM parts lasted 15 years in my truck (seals).
I replaced them with another AAM OEM kit. Going strong since.
You got a howl, it sounds like an installation error to me. There's a pretty specific tightening procedure for pinion preload, sounds like it was over torqued from the start.
08 Cummins
TIMKEN​
SET42Differential Bearing 9.25
TIMKEN​
710558Differential Pinion Seal 9.25
TIMKEN​
HM88610Differential Pinion Bearing
TIMKEN​
HM88649Differential Pinion Bearing
TIMKEN​
HM804810Differential Pinion Bearing
TIMKEN​
HM804846Differential Pinion Bearing
TIMKEN​
HB4021Drive Shaft Center Support
USA STANDARD GEAR​
USA30236 (USA-30236)Axle Shaft Seal
USA STANDARD GEAR​
USA55006 (USA-55006)Differential Pinion Shim
USA STANDARD GEAR​
USA33099 (USA-33099)Differential Crush Sleeve
USA STANDARD GEAR​
USA33142 (USA-33142)Differential Pinion Nut
ABOVE is a paste from a previous RA order
Plus I had these items in a box waiting to be installed.. Can't remember where they go on the 11.5 but here are some more part numbers
HM807010 - Tapered Roller Bearing Outer Race Cup, Steel, Inch, 4.125" Outer Diameter, 1.1250" Cup Width
SET 38 HAVE TWO OF THESE
NP457992
NP926068
SET 416 HAVE TWO OF THESE
3984 HAVE TWO OF THESE
SEALS:
710508 - PINION SEAL
710563 HAVE TWO OF THESE - WHEEL SEAL
SL260034 - Transfer Case Output Shaft Seal
Reactions: krashDH
TIMKEN​
TIMKEN​
TIMKEN​
TIMKEN​
TIMKEN​
TIMKEN​
TIMKEN​
USA STANDARD GEAR​
USA STANDARD GEAR​
USA STANDARD GEAR​
USA STANDARD GEAR​
NP457992
NP926068
SEALS:
Thanks!
Had a howl / whine before I started and it seemed to improve but never went away. At stock power I’d say it would last that long but I’m far from stock. I think that the gear set may be the cause. I was reading that a overloaded gear set will make some noise. Was going to replace the gear set, axel bearings and pinion if they look bad. I torqued the pinion correctly and was in the inlb range.
03’ - 10’ RAM 11.5”AAM REAR DIFFERENTIAL
OUTER WHEEL BEARINGS
Set-38
INNER WHEEL BEARINGS
NP284552 Cup
NP598002 Bearing
WHEEL SEALS
710564
PINION TAIL
NP457992 Bearing
NP926068 Cup
PINION HEAD BEARING
HM807046 Bearing
HM807010 Cup
PINION SEAL
26064030
CRUSH SLEEVE
CS341
SKF CRUSH SLEEVE & NUT
KRS146
Shim Pack - USA Standard
USA-55006
DIFFERENTIAL SIDE BEARING
3984 Bearing
3920 Cup
ALL BEARINGS ARE TIMKEN NUMBERS
Thanks guys this what I ended up ordering. Is there a place for stickies for these type things?
