You mentioned that you got the OD to kick in, if that is the case it should still work. But if it is totally fried, it probably won't. Try spraying some contact cleaner, and rotating the TPS back and forth, than leave it hooked up but off the IP, and take it for a test drive. See what hapens. You have to take the TPS of any way if you are thinking about replacing it, so give it a try.
Yes you quickened the shifts, which tends to rev it out more and waste more fuel, instead of making it work on the lower end were they produce tons of torque.:thumbsup: If you like it to shift quicker leave it, if you want economy, put it back were it was. On mine, if you have to get up and go, or to pass someone, I shift it manually anyway. Just my .02
BTW, is you speedometer working???
If not, your OD won't engage, it needs the signal from the speedo.
