1 - 2 of 2 Posts
Hey guys i have searched on here and cant really find anything that helps me out. I have an A518 auto and it seems to be stuck in park. I have the tranny out of the truck, and i am puttin it in a scout. I dont know if it needs an electrical signal to shift or if it is all manual and its just stuck. i tried turning the shift lever and it wont budge and the input shaft wont move at all. Any help would be much appreciated, Thanks:S:
It's a mostly hydraulic trans. The only electrical on it is the solenoid that tells it that it's OK to shift into OD.
Try rocking the output shaft back and forth while turning the shift lever. You can also pull the OD unit off with the six 11mm bolts and slide the park lever out of the OD. If it doesn't shift then, there's something wrong with the manual shift valve.
1 - 2 of 2 Posts
