about 2 months ago i got my transmission rebuilt. i noticed about 2 week later the truck was running hot and the antifreeze was low so i added some. all was good for about 2 more weeks then the same thing. so i checked the transmission fluid and sure as shi* it is leaking into it. so i took it back to the transmission shop and they said that the clutch plates are fu*ked and i need a new radiator. could this be something they did or just my luck? they wanted a ton for a radiator which is something i can do myself, but i was wondering if the cooler for the transmission is in the radiator or if its seperate. please help
TECH SPECIALIST
its seperate... its under the fuel filter(water seperator)
i had the elbow that goes to the tranny cooler bust and drain all my fuild.. suck to be towed home by a GMC
haha well how about one that will work better and keep the transmission cooler then the stock one
TECH SPECIALIST
if it leaks then ya...if not no.... get u a pressure testere and check if u radiator is leakin
