1 - 3 of 3 Posts
I have a 2003 dodge 2500 with the Cummins engine im having a very strange issue with my a/c system. Fuse number 16 Air Conditioner Compressor Clutch 10 amp fuse. Blows instantly when the ac turns on. but if i disconnect the ac pressure transducer SENSOR. the fuse does not blow. Ive already replaced the sensor with a new one and still the same problem. ANY IDEAS? THANKS.
Have you checked the plugs and wires, making sure nothing is broken or chaffed?
Reactions: rghavana
The AC compressor clutch is seemingly Fried. And Or the wires near the oil filter going to it .
Reactions: rghavana
1 - 3 of 3 Posts
